Not sure if this is the right forum or should be in the builders section.
I have 3 questions please.
1. I have just been clearing leaves and silt out of the drain beneath the gutter downpipes and have used a high pressure jet in this process but no matter how much water goes down the water levels out about 18" from the top. Is this normal?
2. The water also doesn't join the sewer pipe underneath the nearest manhole cover. Is this normal? I have no idea where the water is going, presumably underneath the house. All of our drainage is eventually connected to a pump, which has to pump uphill to the mains sewers.
3. The waste pipes from the sinks and bathroom are also drained into the same drain as the gutter downpipes. Is this normal?
Thank you.
Thank you.
