- Joined
- 22 Feb 2003
- Messages
- 23
- Reaction score
- 0
- Country
I have a rusty downstairs radiator and will have to replace this soon.
Because of the corrosion its beginning to very slightly leak from the rusty areas my idea in the short term was to drain the rad empty.
There is a small pipe underneath on the left hand side of the rad which allows you to attach a hose pipe and a little square "tap" that you can turn with a small spanner / monkey wrench. This I did but found that HOT water started to flow through the hose. This confused me as the central heating system is obviously off at the moment so I must be getting water which is going to the taps. It seems that no water is being drained from the rad (as this would at least be dirty and cold)
Basically I need to know how to close off the rad from all water sourse and then drain
Any help would be greatly appreciated
Tony
Tony
