- Joined
- 17 Feb 2006
- Messages
- 396
- Reaction score
- 4
- Country
I am not a plumber.
New combi boiler fitted. Vaillant 831. Was a system boiler + hot storage tank, header tanks etc. before. Temperature in the shower (mira themostatic) a lot colder now. In fact to get anything like a decent temperature it has to be all the way over to the hot side, way past the safety click button thingy.
But the actual pressure in the shower is a lot higher. In fact almost at hotel bathroom shower pain level.
It seems the cold pressure is far higher. Just did a test. Turned the bath hot tap on (bathroom h&c are all on the same pipes), decent flow, decent temp. Turned the bath cold tap on and the hot flow plummetted. Same in bathroom basin, utility room sink. Can\\\'t really tell in kitchen sink, as it\\\'s a mixer tap.
It looks like when a cold tap is turned on it robs pressure from the cold feed to the boiler.
Can\\\'t see the plumbing layout exactly without some pain, but the cold feed to the boiler is in 15mm and is teed into the cold feed to the kitchen sink. So it\\\'s after at least one other cold feed, and maybe after all the other cold feeds. But is that how water pressure works? Isn\\\'t pressure just pressure, wherever it is?
So, do the cold feeds need altering so the cold feed to the boiler comes first? Or is there some sort of regulating valve which can split a cold supply so I can balance up how much each half of the system gets?
Cheers
Cheers
