Can anyone give me advice on the best material to draught proof the mating rebate on a pair of outward opening timber French Doors. The doors have been manufactured by a reputable joiner and the hardwood frame already has been weatherstripped. Unfortunately I cannot use the milled slit in the rebate of the fixed door to insert a similar length of the weatherstrip provided. This is because I have let in a rebated mortice lock in the centre and two flush bolts top and bottom to secure the door when closed.
The doors are hung on a pair and a half of 4 " 180 degree brass hinges so that they can fold back against the side lights. Although I have adjusted the doors by both bending and packing the hinges, there is still a 5mm gap between the doors. any less than that and they bind when opened.
I had considered the old style copper strip nailed down the rebate of the opening door (can't do closed door or it obstructs access to shoot bolts) which could be bent to meet the closed door,but this is a bit intrusive and ugly on this leaf.
Are there any other draught strips such as self adhesive brushes or silicon strips which would look better but still fill the gap?
