Replaced Drayton 3 way valve withe Siemens CMV3 valve.
Valve works fine on HW only and CH only but when both are called to run together the CH will not shut off on the room stat.
I have to switch the CH to off on the programmer.
Wired up as per the wiring Diagram with the Siemens valve but perhaps I need to swap a wire over in the room stat?.
Any suggestions.
Any suggestions.
