Drayton MA1-Losing the will to live
19 May 2008
Glamorgan
We have just had a new tank fitted and to that a Drayton MA1 valve installed as the other one I used to have to turn by hand! The new valve only operates on CH the wiring to the old valve was as follows
2-Earth
4-Grey
5-White
10-Blue
6-Orange
The plumber has wired the new one as follows
4-White
6-Grey
8-Orange
2-Blue
11-Earth
I am not sure what the old valve was and I can't get hold of the plumber to come back. Please, please help as it is really doing my head in! :x
Presumably the numbers are the terminals in a wiring centre, If so, we need to know what else is connected to each terminal as wiring is not standardised.
Post a list and it will be sorted.
Right then here goes, remembering I'm no expert. The connector block is a strip of eleven
Cylinder Stat
Red-5, Blue-7, Yellow-6, Earth-10
Valve
Blue-2, Grey-4, Orange-6, White-8, Earth-10
Pump
Blue-2, Brown-8, Earth-10
Feed
Brown-1, Blue-2, Earth-10
Control
LH side (CH) Black-2,red-1, Earth-10
RH side (HW)Blue-7, Red-3, Yellow-5
There are two other wires coming up to the box presumably room stat
1) red-3, Black-4, Earth-10
2)Black-2, red-8, earth-10
One last question, when you take the actuator off are you supposed to be able to move the valve by hand?
you told us your plumber had wired the new one as in your earlyer post.
now your colours on the valve don't match what you said he had done.
on your programmer turn on hw so its calling but heating off
you should have live at no 5. yes or no ?
