Had/have a few problems with Drayton trv4's that were/are fitted in my old as well as my current house (but I rented my old place, so I was less bothered).
Seen other posts on this forum where people experience them not working anymore after the summer. Had this problem as well, so in order to inspect it I screwed the white top bit off. Not sure if that was the wisest move, but pretty irreversible move anyway (?) - the radiator in question is at full blast now.
So now the main questions are:
- How can you tell if they're broken ?
- If there are not, can you just screw it back on ?
- If so, how to reinstall them and actually make them work again in the process
If replacing is the only remedy, where to get a good deal on them ?
Do they come with the other metal bit as well ?
What is the procedure for replacing them ? Do you have to empty the system, do the job and then refill it perhaps ?
Thanks,
DIY-numpty
Thanks,
DIY-numpty
