I'm planning to change some old radiators on my CH system and so was looking to also replace the old TRV's with some Drayson TRV4's, which I've already done on a number of radiators over the years.
I came across a "new" version of the TRV4, which has auto-balancing technology built in. My understanding is that on installing you change a setting based on the size of the radiator/btu output it will be fitted to and I assume the lockshield valve is left fully open, since the TRV then balances the flow through the radiator.
I assume the idea is that on a CH system where all radiators have these auto-balancing TRV's fitted then it should not be necessary to balance any radiators and they would all get hot without issue? However, is it worthwhile fitting these on a system with 16 radiators, when only, for example, 3 radiators have these auto-balancing valves fitted. I guess it would work for those 3 radiators, but then there would be a mix of manually balanced and self-balanced radiators and since these valves look identical to the classic TRV4 versions, it may be difficult to remember which is which. However, I guess that once balanced all the radiators on a system shouldn't need to be changed again, apart from when they are replaced.
Is this new auto-balancing technology worth paying the extra for or is it just a gimmick?
I confess, despite already fitting some of the classic TRV4 valves a few years ago, I hadn't realised they could be altered manually to balance the radiator, rather than balancing using the lockshield valve. I only came across this ability, which requires a special tool that must be purchased, while trying to understand what the new auto-balancing valves actually did.
I would appreciate your thoughts and experiences.
