I need to cut through 16mm engineered flooring neatly along the join to patch in about 1 sq metre. Are there circular cutting blades on a Dremel large enough to make a vertical cut at 90 degrees or would the body of the machine get in the way and force the blade off-vertical?
Many thanks for opinions.
