Drilling through porcelain tiles?
27 Mar 2009
Yorkshire
What type of power drill is best for drilling through porcelain tiles? Or is it the drill bit thats important?
Should I try with my cordless 18v 3.0amp Makita drill with perhaps some Tungsten Carbide masonary drill bits? Or should I be using something else?
It's the drill bit that is important, you need a diamond drill bit for those tiles, pop into somewhere like Tile Magic they will stock them
Thanks. Ive just noticed these plasplug diamond drill bits, are they any good?
http://www.plasplugs.com/acatalog/Cool_Cut_Drill_Bits___Kits.html
Yes I used one of the 25mm ones to run some pipes through tiles it worked well.
For smaller holes, use the arrow/heart shaped things. You need to keep those diamond drill bits cooled with water if you want them to last a decent amount of time.
Nozzle
You may find it easier to stop the drill bit skating all over the tile if you stick some masking tape on the tile and drill through that
