Hi there,
We've got a dripping tap - hot water (so left hand side). There's a space at the back of the tap for what looks to be an allen key but none of the keys are turning it in a way which I can get the tap off.
Unfortunately I think we might be looking at a replacement tap. I want to avoid soldering copper if possible.
Currently - as you can see from the photos - we've got cooper tap for hot then copper tap for cold which also connects down to the isolation for the dishwasher.
Any thoughts on how best to replace the tap if I need to go down that route? Presumably it means cutting the pipes - is there a connector I can use to connect the copper pipe to the Flexi hose for the tap?
Thanks!
Thanks!
