Driveway Sub base
15 May 2009
West Midlands
I am getting a drive built at my house and I have to fill the area to raise the driveway. So far, I have had 2 skips of rubble dropped. The house side is ok now, but the road side still needs to be raised a foot or so. Hardcore seems to be a very expensive option, the cheapest I can get is £28 a ton and I need 8-10. The guy who is paving the drive, suggested soil, instead of more rubble. I didn't go in detail of why. But he seems to think, that the soil won't sit in future, as there is rubble underneath.
Does his suggestion make sense?
Or would rubble be better option?
Or should I get actual hardcore?
I do plan on putting a few tones of hardcore, once the drive has been raised a bit more.
As long as the rubble is good quality, ie no combustible material or other polluting material, eg gypsum, timber, composting material, you can fill up to about 150mm below your required level.
Top it all off with 150mm hardcore.
Don't forget you should be whacking it each 150mm, rubble and/or hardcore
If you wanted a cheap material for granular infill in the larger voids, prior to topping with something like MOT type 1, try quarry waste. It's 0-4mm and cheap.
As RH has said you need assurances that the hard core is sulphate free.
Otherwise bite the bullet and buy in m.o.t. type 1 and have peace of mind.
Do you have any experience with recycled hardcore? Is that any good? It would be broken down to 40mm.
You can get a grab bag of MOT1 from Jewson's for £28+vat. Try a local merchant for a price on a full 10 tonne load loose direct from the quarry you should be looking at £15 - £16 a tonne +vat I reckon. ;)
Cheapest I'm quoted is.
£21 + Vat for 10 Tonnes
But recycled 6F2 Crushed Brick and concrete is half price?
Is it worth going for the recycled stuff?
A quick reference to this link shows that 6F5 is 100mm-75mm crushed hardcore, 6F2 is 75mm down to dust.
http://www.recycled-aggregates.co.uk/6f2.html
I would suggest, for your application, ie the driveway, 6F2 might suffice with perhaps a thin layer (100 - 50mm'ish) of MOT Type 1 to take up any hollows/voids.
Check with whoever is laying the top surface first.
In a situation where a sand blinding and DPM was to be installed, I'd suggest finishing with 150mm of MOT Type 1.
Don't forget to whack each 150mm'ish layer.
A more detailed spec of the materials are here:
http://www.standardsforhighways.co.uk/mchw/vol1/pdfs/series_0600.pdf
Table 6.1 Pages 38 & 41
