I will be drylining my back bedroom within the next couple of days and have read a lot on here that is invaluable however one thing that I'm not so sure about is the following.
What do you do when you have a run of boards that no matter what you do will not end up with a tapered edge both side of an internal corner allowing the corner to be filled and sanded smooth?
Do you sand the edge of the board to a taper and then pva it prior to filling or is there a better way?
All help greatly appreciated
