Hi All,
I’ve had a Hotpoint HUD61P dual-fuel cooker (gas hob, two electric ovens) for around 16 years, connected via a standard 13A three-pin plug into a dedicated socket behind it, installed this way by the original builders ~2010. There’s also a red cooker isolation switch on the wall.
Despite the original cooker being rated at approximately 4.8kW, it’s worked fine without any apparent electrical issues throughout that time. We only use one oven.
Since it’s now discontinued, I’m considering replacing it with a Hotpoint dual fuel HDD6GDC2WX, rated slightly lower at 4.4kW.
My question is, given that the existing cooker has worked perfectly well on this setup for 16 years, could the replacement realistically work just as well, particularly as we’d continue using only one oven? Or is there a significant difference I’m overlooking?
Appreciate that the manufacturer specifies hardwiring, but interested in the practical electrical reasoning and experiences of electricians who’ve encountered similar setups.
Thanks in advance
Thanks in advance
