My semi was build in 1964 and I've lived at this address since the mid 90s. No major work has been done since moving in.
In April, British Gas removed the copper entry pipe and replaced it with a plastic pipe (the whole street was done). The yellow/green earthing wires are now no longer there.
I distinctly remember green and yellow wires with silver clamps on the old pipe. The gas meter's in a very small cupboard under the stairs and all I remember is that the wires disappeared behind the meter.
I got them to check it today and they say that as it's now plastic, the earthing isn't required. They think that because it's a 60s house, the wire probably went into a metal spike in the ground and not into the meter. (That's how I remember it as well - no wire going into the fuse box from the gas meter or gas pipe).
I looked under the floorboards and I can see about 75cm of yellow/green wire just sitting in the rubble.
(1)Couldn't they have just taken the clips off the old copper entry pipe and placed them on the copper internal gas pipes instead?
(2)They said that I should get an electrician and bond the wires from the internal gas pipe to the fuse box. Doesn't that spike in the ground
thing work any more?
Hope someone can help
