My incoming Gas and Water are in the Kitchen under the sink. Neither is earth bonded to the Consumer unit which is by the front door. My question is this. Do I run 2 x 10mm green/yellow to the CU, that's one from each pipe. Or should I connect a short length of 10mm green/yellow between the gas and water pipes and then run a single wire to the CU? All help appreciated. Steve.
