Class 0 refers to equipment that is not "single fault safe", that is a single reasonably foreseeable fault could render the enclosure live in a way that will not be disconnected by protective devices, I'm pretty sure class 0 equipment is not supposed to be sold in the UK/EU.So the safer option, where there is doubt, is to connect them as a class 0?
I presume you mean that it is safer to have less (or no) touchable earthed items? If so, I agree - but that applies to anything (and not only 'electrical' things), not just to double-insulated electrical equipment.It is thought that double-insulated is safer than having earthed items ...
Again, if you're saying that it would be better to have no touchable earthed items in the home, then I would agree (but achieving that would often not be very easy).therefore it would be better to have all double-insulated appliances and no earthed items in the home.
As above, if I have correctly interpreted what I think you were really meaning by what you wrote, then I don't disagree.You are free to disagree.
That depends upon what 'past' you're talking about - ther was a time when a substantial proportion of electrical accessories were brass.It was much easier in the past, most if not all light fittings were ceiling rose and pendants which were all made of plastic, no earth required.
That would surely not be allowed - and for that reason, as has been said, Class 0 items cannot be legal sold in UK?So the safer option, where there is doubt, is to connect them as a class 0?
Pragmatically, I would probably do the same but, as you say, some people would (understandably) be reluctant to do that in violation with (often 'strong') MIs which, as I recently said, seem to be unnecessary and misleading.So the question is, if one either has a notionally class 2 device that they either suspect is not up to class 2 standards, or the installation conditions make it difficult to maintain those standards what should one do?
1. Do nothing, ignore the problem?
2. Convert the equipment, or at least part of it, to class 1 by adding an earth connection?
3. Refuse to install the equipment.
I would personally go for 2 but I can see why some people would be reluctant to go against manufacturers instructions.
No - fewer (or no) touchable earthed items.I presume you mean that it is safer to have less (or no) touchable earthed items?
I did not have time to include everything.If so, I agree - but that applies to anything (and not only 'electrical' things), not just to double-insulated electrical equipment.
That is why it is not done.Again, if you're saying that it would be better to have no touchable earthed items in the home, then I would agree (but achieving that would often not be very easy).
I was really meaning what I wrote by what I wrote.As above, if I have correctly interpreted what I think you were really meaning by what you wrote, then I don't disagree.
Whilst, as you know, I agree with the concept you are championing, I don't think that "necessary evil" is a fair description - "unfortunately necessary" or "necessary compromise" would probably be better.I cannot add to that - except to say that generally speaking people think earthing is a good thing; it is not; it is a necessary evil.
You're probably never going to change my life-long habit of of often getting the grammar of less/fewer wrong but, that aside, I'm glad that you appear to agree with me!No - fewer (or no) touchable earthed items.
Fair enough, but you could saved some of your time by not including "double-insulated" in what you typed (thereby implying that the comment was specific to double-insulated electrical items), when what you were writing/implying would actually be true of any electrical item, not to mention pipework, radiators, metal window frames and cutlery etc. etc.!I did not have time to include everything.
Are you merely agreeing with me that we do not avoid having any touchable earthed metal because it would be impractical to achieve that?That is why it is not done.
I hope you get someone to proof-read any official documents.You're probably never going to change my life-long habit of of often getting the grammar of less/fewer wrong
I sometimes do, although it's much more common for me to be proof-reading what others have written. However, the primary/crucial purpose of that is always to ensure that what is written is 'clear and unambiguous', rather than to identify 'incorrect' grammar or spelling. It's probably also the case that many of the people who read what I write (or whose writing I read) are no more correct in their grammar or spelling than am I!I hope you get someone to proof-read any official documents.
Whilst there are situations in which it is 'simple', I don't think that it's always quite as straightforward as you imply.It is very simple:
It's essentially a one-sided issue. "Fewer" always refers to 'counts', and "less" to quantitative things. You will rarely, if ever, see "fewer" being used other than in relation to counts, but very many people (hence, perhaps, 'common usage'?) often use "less" to encompass 'fewer counts' as well as 'as smaller quantity of'. The issue therefore only really relates to the use of "less", not of "fewer" (which is almost always used correctly, by any definition).Fewer applies to plural items - not as many - and less applies to single items - not as much. ... Fewer slices, less bread.
As so often, that depends entirely on what one means by 'wrong'.And yet you keep getting it wrong.
