i am fitting a ceiling light but the earth wire from the ceiling is too short to reach the connector, is it ok to connect this to a terminal block and then use some more earth wire to connect up to the lighht.
Also with another light I have too many earth wires to connect to the block supplied with the light, can i use a larger block to fit these wires and then run some earth wire to fit in the block supplied with the light
Or any other suggestions
