Earthing a new light fitting
30 May 2007
Cambridgeshire
Hi
Is this light fitting earthed OK? The old light fitting was earthed using the same cable and method (i.e. chock to bracket).
Out of the box the chock was screwed down to a small metal prong on the light fitting; this gives no maneuvering for connecting the cables and the final connecting up to the bracket.
The prime need is to earth the light fitting and that is why the supplied earth terminal was screwed down to the prong on the fitting. Earthing just the bracket and not the prong cannot ensure the light fitting has an adequate earth since it would rely on the light fitting making good contact with the bracket
Do what you have done to earh the bracket but also add a second earth lead from the terminal block in the picture to the terminal screwed to the prong in the light fitting.
Thanks for replies. I have done as suggested and earthed the cable to the prong by a connector block (with hindsight make a lot more sense). All working fine.
Worse than that - it also relies on the screw into the ceiling making good contact with the bracket.
I wouldn't bother earthing the bracket.
