Hi All,
I continue to find curious quirks in my new-ish (2004) install (NICEIC certified installer...).
Garden lighting is installed, off a garage style consumer unit fed from the main cu box. It is protected by a 30mA RCD, and external wiring is 3-core SWA. One of the cores has been used as the earth...fair enough so far.
But the armour is not connected to earth at the consumer unit, consequently the galvanised conduit boxes through the garden where the SWA connects to the low voltage transformers are also not earthed - should they be?
My thought is yes...but...I'm about to have a PME connection provided by EON (no proper earth connection...see earlier posts!!!) and its crossed my mind that if they were earthed would it not be equally potentially dangerous in the event of a neutral supplier fault?
(similar to say bonding a metal outside tap...in prep for which I've just installed a section of 15mm plastic pipe in the copper run to the outside tap to insulate it from the rest of the bonded pipework)
Thoughts?
cheers
Thoughts?
cheers
