Interesting. To me, "socket screw" implies that it has a head with a female socket (e.g. for an Allen key).I've never thought about it but we call them socket screws too!
Kind Regards, John
Fair enough, but I usually see that abbreviated to just "socket screw"We call those socket cap screws!
I always thought a plate was for food.Plate screws.
Indeed - but it seems that this is a case of the opposite - the same thing having different names ....Different things frequently have the same name.
Oh, I see, is that where the "socket" (of "socket screw") comes from?! (I confess that I hadn't thought of that possibility!) If so, do you also recognise "switch screws", "FCU screws" etc. ?It is a screw which holds the socket in place. What else would they be called?
... and, FWIW, that's definitely what I would call them.I might say Faceplate screw
By definition, obviously.Oh, I see, is that where the "socket" (of "socket screw") comes from?! (I confess that I hadn't thought of that possibility!) If so, do you also recognise "switch screws", "FCU screws" etc. ?
Indeed there are. I have a suspicion that all the things we've been talking about (fully threaded and designed to go into threaded holes, rather than to 'screw' into materials like would) may be classed as 'machine screws'. A more interesting (and probably less well understood) distinction is between a machine screw and a bolt (intended to be used with a nut). IIRC, a bolt is not fully threaded, whereas a machine screw is - but I may well be wrong in that recollection!There are even machine screws for holding machines together.
