Guys,
I'm looking at having / doing a re-wire in our house and have been speaking to a few electricians who are willing to advise, check while all chases are exposed and floorboards are up, recomend changes and finally sign off.
I've been researching and reading and am not a complete novice but when it comes to the earthing side I'm at a bit of a loss.
The two sparkies i've spoken to have both said different things. Our current set up is;
An old cast iron main fuse
No earthing running from that to the CU
Earth bonding to the gas main (2mm!!)
NO (I know it seems impossible) water stop tap coming into the property. (I've lived here for 2 years and have raised all floorboard in all likely and unlikely areas and have turned up nothing!
The conflicting advise;
1st sparky said not a problem, 10mm earth to both gas and water (if he finds it) and what ever happens on the supply side of the CU doesn't matter (?!)
2nd sparky said I would need to have the provider change the isolator fuse with an up to date unit which would bring in earth which would be utilised along with the 10mm earth to water and gas.
Who is right? I've been waiting a good while for the main fuse to be changed and don't want that to be the thing that stops all the work to the house going ahead if it doesn't have to just because the provider doesn't really care!!
Is this an area that is open to interpretation? It doesn't look like it according to the reg's and rules around earthing but I'm not an expert and want something installed that will be safe.
Any advise would be much appreciated.
