Definitely. We here can but speculate.The only suitable advice for the OP at this stage is to get a qualified spark in to check it out.
Kind Regards, John
.... but would they use ordinary unsheathed G/Y 6491X for that? - it seems unlikley.Have worked on some TNS systems which are directly fed from substations before, it is a possibility ...
Kind Regards, John
Fair enough.I've worked on a supply fed direct from a substation which was supplied like that with 6491X, but never seen a direct supply as small as the OPs fed in that way.
Would it still count as TN-C-S if the split of the CNE were outside of the consumer's property?Also I have worked on CT chamber incommers with a 6491X along side the incommer, but I forget what the earthing supply type was. I have a feeling it was TN-C-S with the earth attatched to the CNE conductor presumably going to a DNO rod?
Aren't we both saying the same thing - i.e. that it would be TN-S as far as the consumer was concerned, since the N and 'earth' would enter the property separately, even though there was a CNE conductor before it split into N & E somewhere external to the property?No, but then again it would be a neutral supply rather than a CNE in that case, and the two wouldn't be connected together at the CT chamber.
For the average consumer in the average house in the average street it would be TN-S but for the more discerning consumer who has anxiety about his or her CPC not being at true ground potential this set up would not be TN-Si.e. that it would be TN-S as far as the consumer was concerned,
... and, even then, it won't be at the true potential of the mass of the earth if there is any current flowing down it.No cpc is ever at true ground potential except where it enters the ground.
It could be dangerous - but it surely all depends where that G/Y goes? The cutout looks pretty new doesn't it? Whoever installed it presumably must have been happy about the earthing arrangement?As it is at the moment it ought to be isolated as it appears to be dangerous.
