    Dismiss Notice
easiest wireless alarm to arm/disarm
Discussion in 'Alarms, CCTV & Telephones' started by RobTi, 1 Aug 2020.
  1. RobTi
    RobTi
    20 Oct 2010
    621
    Thanks Received:
    13
    Lanarkshire
    Country:
    Hi looking for an alarm that is really easy to arm/disarm for my elderly mother and also would send alerts to mobiles, I was thinking tags but don’t know how that would work at night to part arm or a simple keypad ?
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    8,583
    Thanks Received:
    1,305
    Sheffield
    Country:
    Pyronix Enforcer ....you could use auto part with tags it automatically part sets unless you go out by the exit door and then it switches to full set ...does she have broadband ?
    • Thanks Thanks x 1
  4. RobTi
    RobTi
    20 Oct 2010
    621
    Thanks Received:
    13
    Lanarkshire
    Country:
    Yes she has broadband. She was ready to get a company in a couple of years back but he started talking about part arming and she got confused.
  5. RobTi
    RobTi
    20 Oct 2010
    621
    Thanks Received:
    13
    Lanarkshire
    Country:
    Should say she lives in one level semi with no walls higher than gutter level approximately 2.5m needs 2 door contacts and 3-4 pir.
  6. secureiam
    secureiam
    20 Jun 2014
    5,156
    Thanks Received:
    640
    Lancashire
    Country:
    Quick arm on some panels would require the user to press 1 key
    depending on the layout when the entry tone has started use the prox tag to disarm
    Or you could set it up to arm and disarm on timers, which could use a prox tag to disarm out side those hours.
    so she would need to do nothing, you would get the message to say the system has been armed or disarmed.
  7. sparkymarka
    sparkymarka
    16 Feb 2011
    8,583
    Thanks Received:
    1,305
    Sheffield
    Country:
    Enforcer would probably been the cheapest option with free WiFi card and first year free £36 after ...see if she gets on with it ok
  8. DIYSOS2018
    DIYSOS2018
    17 Jul 2018
    216
    Thanks Received:
    8
    Country:
    How do you set this Sparky?
  9. Sponsored Links
  10. sparkymarka
    sparkymarka
    16 Feb 2011
    8,583
    Thanks Received:
    1,305
    Sheffield
    Country:
    Enable intelligent set ...
  11. DIYSOS2018
    DIYSOS2018
    17 Jul 2018
    216
    Thanks Received:
    8
    Country:
    Far too many beers consumed last night. So obvious now I read your answer haha
  12. RobTi
    RobTi
    20 Oct 2010
    621
    Thanks Received:
    13
    Lanarkshire
    Country:
    And how would this work if she just answered the door ?
  13. DIYSOS2018
    DIYSOS2018
    17 Jul 2018
    216
    Thanks Received:
    8
    Country:
    Unless she’s answering the door after the setting the alarm immediately before going to bed you’ve no issue
  14. RobTi
    RobTi
    20 Oct 2010
    621
    Thanks Received:
    13
    Lanarkshire
    Country:
    thanks so i get the fob will part arm when she goes to bed and unset in the morning, but how does intelligent set work, could google but hoping for a more common sense answer here ?
  15. DIYSOS2018
    DIYSOS2018
    17 Jul 2018
    216
    Thanks Received:
    8
    Country:
    It will assume part set each time the panel is armed unless during the set timer a final exit input is triggered in which case it will flex to full set
    • Thanks Thanks x 1
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
