easiest wireless alarm to arm/disarm
20 Oct 2010
Lanarkshire
Hi looking for an alarm that is really easy to arm/disarm for my elderly mother and also would send alerts to mobiles, I was thinking tags but don’t know how that would work at night to part arm or a simple keypad ?
Pyronix Enforcer ....you could use auto part with tags it automatically part sets unless you go out by the exit door and then it switches to full set ...does she have broadband ?
Yes she has broadband. She was ready to get a company in a couple of years back but he started talking about part arming and she got confused.
Should say she lives in one level semi with no walls higher than gutter level approximately 2.5m needs 2 door contacts and 3-4 pir.
Quick arm on some panels would require the user to press 1 key
depending on the layout when the entry tone has started use the prox tag to disarm
Or you could set it up to arm and disarm on timers, which could use a prox tag to disarm out side those hours.
so she would need to do nothing, you would get the message to say the system has been armed or disarmed.
Enforcer would probably been the cheapest option with free WiFi card and first year free £36 after ...see if she gets on with it ok
How do you set this Sparky?
Far too many beers consumed last night. So obvious now I read your answer haha
Unless she’s answering the door after the setting the alarm immediately before going to bed you’ve no issue
thanks so i get the fob will part arm when she goes to bed and unset in the morning, but how does intelligent set work, could google but hoping for a more common sense answer here ?
It will assume part set each time the panel is armed unless during the set timer a final exit input is triggered in which case it will flex to full set
