- Joined
- 24 Jun 2021
- Messages
- 4
- Reaction score
- 0
- Country
Hi all,
We're currently in the advanced stages of buying a 4 bedroom detached house in the midlands (built approx 1980) for us to live in (i.e. not to rent) and have had an EICR carried out. The result came back "UNSATISFACTORY" with the following concerns:
As you can see, there's a few C1s (a.k.a "Danger Present. Risk of injury. Immediate action required."). Any advice would be appreciated as I'm not an electrician!
Are all these items needed if we don't want to fix the C3 issues? Is it worthwhile biting the bullet and getting the C3s done at the same time anyway?
Thanks for reading.
- 5.6 Condition of enclosure(s) in terms of fire rating etc (421.1.6; 421.1.201; 526.5) C3
- 5.14 Confirmation of indication that SPD is functional (651.4) C3
- 5.15 RCD(s) provided for fault protection - includes RCBOs (411.4.204; 411.5.2; 531.2) C1
- 5.16 RCD(s) provided for additional protection, where required - includes RCBOs (411.3.3; 415.1) C1
- 5.17 Presence of RCD 6 monthly test notice at or near equipment, where required (514.12.2) C1
- 5.18 Presence of diagrams, charts or schedules at or near equipment, where required (514.9.1) C1
- 7.7 Adequacy of protective devices: type and rated current for fault protection (411.3) - HI End to end readings on lives on socket circuits C2
- 7.12b *for the supply of mobile equipment not exceeding 32 A rating for use outdoors (411.3.3) C2
- 7.12c *for cables concealed in walls at a depth of less than 50 mm (522.6.202, .203) C2
- 7.12e * Final Circuits supplying luminaires within domestic (household) premises (411.3.4) C2
- 9.7b Installed to minimise build-up of heat by use of “fire rated” fittings, insulation displacement box or similar (421.1.2) C1
- Is the house an immediate death trap?
- Should we get the existing owner (who still lives there) to fix the items?
- Or should we proceed with the sale and fix the issues ourselves? Perhaps haggle on the house price?
- New 18th edition consumer unit (the old unit is 60947-3 if that helps?) -- approx £600
- 16 x fire rated spotlights (as in downlights?) -- approx £700.
- Surge protection unit -- approx £110
- New meter Tails -- approx £60
Thanks for reading.
