EICR question
2 Jul 2022
4 fluorescent lights that had been fitted years ago at the top of a tall (over 6 metres to the apex) building, used plug and sockets running back to a 4 gang light switch.
(Rightly or wrongly they had plugs and sockets to make it easier to remove at a height).
An EICR has said that the 4 gang switch needs to be replaced by 4 x 20a DP switches.
Does it really need 4 x 20a DP switches or would 1 x 4 gang 20a switch be compliant?
Or
If I change the plug and sockets to hard wired straight to the 4 gang switches, would that be compliant, or do they actually need 4 x 20a DP switches (seems excessive to me)
Hope that makes sense...?
I would politely ask the spark who produced the EICR for the reference number to back up his coding as that sounds wrong to me
And what’s the fuse rating in the plug?
The fuses are all 3a (4 lights each on a single cable 1 from each switch)
I have a plug and socket for my lights Ceiling light.jpgCeiling rose.jpgand that is a standard method, there are other makes, and I see no reason that should raise any code with an EICR. This one 1790368174408.png has been used for years, even an emergency version.
