That's entirely a matter for the inspecting Electrician, although what is connected to it may be a major factor in that judgement.Hi guys,
I have an MK h7860s AC type RCD in my fusebox.
For EICR, is it a C2 or C3? Does it HAVE to be replaced with a Type A RCD? Or is it still acceptable?
Same here. I have about a dozen type AC RCDs here, spread over several CUs, and I have no intention to change any of them simply because they are Type AC.I have type AC in my home and do not intend to chage them anytime soon.
For general purposes, Type AC RCDs may be used.
I don't disagree with that and, in any event, I doubt that we will have much choice, since I suspect that it will become increasingly difficult (eventualy impossible?) to buy Type AC devices from any of the mainstream wholesalers and suppliers.I would not normally be unduly worried with most domestic properties but as a correctly perceived possible problem so new installs does make some sense not tocarry on with type AC.
they actually said they were type B on the boxes.
Yes it was, it should have said curve B not type B, but said type B on the box.Won't that be the current curve, not the RCD type?
I'm not so sure about that "should" ...Yes it was, it should have said curve B not type B, but said type B on the box.
It has always been known as Type B, Type C and Type D for circuit breakers.Yes it was, it should have said curve B not type B, but said type B on the box.
It would not have confused anyone had they not decided to use very well-established terminolgy to mean something totally differentYes indeed the overcurrent curve type and the RCD type are two different things, with a RCBO there arre two types of "types" so it can confuse some.![]()
