Hi all.
A friend of mine wants to fit an electric boiler and a timer in his coffee shop. Can anyone tell me how you would wire them up ( and what fuse rate) please? I understand that a fused switched double pole switch one metre away from the boiler is needed. Would 13 amp fuse be enough? Would you run the cable from the board to the boiler or from the ring to the boiler? How would you fit the programmer in and does it have to be protected by a 3 amp fuse? A drawing would be much appriciated. Thank u.
