I had a shower installed the electrician ran off cooker supply as i dont use it council came round to do check cut it of as unsafe is this right with thanks
Did the council say that was the reason? More likely a lack of sup bonding or no RCD - Although an RCD is not required by the regs, the council guys always look for one and question if not fitted.
RCD is only required if the manufacturer specifies it.
If the manufacturer just specifies work to BS7671 then strangely RCD protection is not currently a requirement.
