Electric Door Chime
15 Aug 2009
I have an electric door chime (Byron 776) which has an internal transformer.
I'm not too keen on having grey T&E running from the chime to the fuse box; the chime will be located above a door and highly visible in the hall.
Has anyone any suggestions of how o make the cabling appear unobtrusive; please note, I do not intend to use trunking of any kind.
Thank you
Without using trunking, the only option is to cut a channel into the wall, put the cable in then plaster over it. Redecorating afterwards.
If that isn't appealing, mount the chime higher up near the ceiling and wire it to the lighting circuit.
