    Dismiss Notice
Electric heaters - what would you reccomend?
Discussion in 'Plumbing and Central Heating' started by shabbaranks, 19 Jul 2016.
  1. shabbaranks
    shabbaranks
    4 Jan 2012
    176
    Thanks Received:
    Country:
    Hi guys,
    We're building a garden cabin 6.5 meters x 4.5 and we're looking for suggestions on the best electric heaters. Ive been looking at haverland but was wondering if anyone can recommend another make or solution please? I used the haverland calculator which suggested I get 2 x RC12B's - is this a little over kill?
    Thanks as always :)
  2. Sponsored Links
  3. flameport
    flameport
    10 Mar 2007
    9,901
    Thanks Received:
    1,980
    Poole, Dorset
    Country:
    Heating requirements depend on the heat loss of the building, same as for any other.
    Unless you really wanted to throw £600 away on those Haverland things, then one of these: http://www.argos.co.uk/static/Product/partNumber/4154017.htm
    would do just as well. If after using it in the winter it does not output enough heat, you could buy a second one.
  4. shabbaranks
    shabbaranks
    4 Jan 2012
    176
    Thanks Received:
    Country:
    Thanks that's probably not a bad idea to be fair. Even just go with a smaller mains wired electric heater which kicks out say 1000w and then add if required.
    I appreciate these are an expensive brand - do you know of any others?
  5. OwainDIYer
    OwainDIYer
    5 May 2010
    4,554
    Thanks Received:
    698
    Stirlingshire
    Country:
    Other expensive brands: Rointe, Fischer, any other 'German' heater filled with magic super clay.
    If you want a heater which will circulate the air and warm the whole room consider something like
    https://www.machinemart.co.uk/p/hh503e-fan-heater/
  6. shabbaranks
    shabbaranks
    4 Jan 2012
    176
    Thanks Received:
    Country:
  7. shabbaranks
    shabbaranks
    4 Jan 2012
    176
    Thanks Received:
    Country:
    Guys, excuse my stupidity but.... You can get panel 2kW heaters for £200 and you can get convection 2kW heaters for £20 - how do they differ as obviously they are both 2kW?
  8. PullerGas
    PullerGas
    11 Jul 2015
    6,062
    Thanks Received:
    1,205
    Glasgow
    Country:
  9. big-all
    big-all
    12 Jul 2004
    18,951
    Thanks Received:
    1,487
    Surrey
    Country:
    unless its super insulated you will need at least 3kw possibly more
  10. Sponsored Links
  11. shabbaranks
    shabbaranks
    4 Jan 2012
    176
    Thanks Received:
    Country:
    It is proper insulated with 50mm celotex and then insulation on top of that we then have ply and plasterboard. I did the calculations based on the size which came back 1.8kW so 1.5 to start with should be fine.
  12. big-all
    big-all
    12 Jul 2004
    18,951
    Thanks Received:
    1,487
    Surrey
    Country:
    you need it to be greater than the heat loss otherwise you will be stuck around 15 degrees on cold cold cold days
    if its occasional use with heating off overnight you would be better off with 3kw plus thermostatically controlled that will get to temperature quicker then turn off wasting less energy warming up
  13. muggles
    muggles
    28 Oct 2005
    13,330
    Thanks Received:
    3,072
    Daventry
    Country:
    They differ in price only - both will use the same amount of electricity and give you the same amount of heat. Buy the cheap ones
  14. OwainDIYer
    OwainDIYer
    5 May 2010
    4,554
    Thanks Received:
    698
    Stirlingshire
    Country:
    They differ by £180. :D
  15. big-all
    big-all
    12 Jul 2004
    18,951
    Thanks Received:
    1,487
    Surrey
    Country:
    i prefer fan heaters for more direct aiming
    basically you enter the cold space aim the fan heater at the area you are sitting at or using most so you get full benefit off the heat as it gradually spreads to the colder areas
    for long unattended times [more than around 10 mins] or with kids or animals i would avoid a fan heaters unless out off reach as they can get very hot iff airflow is restricted
    yes they have protection to stop problems and should be fine but would hate the 1% chance to happen to you
    i actually leave my argos £12 fan heater unattended on frost setting over night but it sits on top off my woodburner so if it did fail or catch fire it would simply melt untill it blew a fuse as theres nothing flamable within 2ft sideways and 4ft vertically
  16. PullerGas
    PullerGas
    11 Jul 2015
    6,062
    Thanks Received:
    1,205
    Glasgow
    Country:
    Surely a split heat pump is going to give you the best if both worlds, fan heater & 2.5 times cheaper to run than anything else!!
  17. muggles
    muggles
    28 Oct 2005
    13,330
    Thanks Received:
    3,072
    Daventry
    Country:
    But frighteningly expensive to buy and install
Loading...
Share This Page
