Hello
Im replacing an old gas cooker with an electric oven (2.7KW) and separate gas hob which has an electric ignition. Nearby there is an old 45A CCU running on a radial protected by a 32A mcb at the Consumer unit.
Can I replace the CCU with a 13A FCU and wire both the oven and hob into it? Also (as Im assuming there will be spare acpacity on the circuit)can I then run a spur from the FCU to wire in a 13A socket?
Hope someone can help
Cheers
Matt
Cheers
Matt
