Ha.
You try it.
You try it.
If your only points of contact are Live and Neutral then no current flows to earth. A dry carpet does not provide any path to earth.What about the current flowing through you to EARTH and not flowing through the Neutral?
I wasn't recommending it.Ha. You try it.
As I said, levitating.If your only points of contact are Live and Neutral then no current flows to earth.
Who said it was a dry carpet.A dry carpet does not provide any path to earth.
So, in normal day to day living -
when only a live line conductor is touched does a person feel anything and does an RCD operate?
If you have a modern consumer unit, how is it possible to still get a shock - what wiring faults can bypass the RCD protection? Can faulty appliances give you a shock even if you a have correctly installed circuit with a modern consumer unit? Cheers, S
Do I take it you think the answer to both is 'no'?Arrrgh, don't you start we have enough trouble with Mr (?) CockburnSo, in normal day to day living -
Yes, indeed - sorry 'bout that.No it won't. It will limit the time for which a current above a threshold level (e.g. 30 mA) can flow.2) An RCD will limit the current which can flow through you to earth
Possibly. Possibly not.So, in normal day to day living -
Possibly. Possibly not.and does an RCD operate?
Possibly. Possibly not.Who said it was a dry carpet.
http://www.nerdware.org/doc/dogphone.html
Only if you are levitating.However, as stated before, if we had touched live and neutral (rather than earth) then the RCCD would not have tripped as the in/out current would have balanced.
You, too, are thinking CPC rather than earth.
I knew I piddled in the garden for some reason!!.....and wet the earth rod.....![]()
Move away from that patch of carpet NOW.Shouldn't laff but PMSL here!!![]()
Do it on the compost heap - it's good for it.I knew I piddled in the garden for some reason!!![]()
Build some kind of platform over the compost heap, with steps up to it, so that they can help it along too.Oh yes, just remembered! 2 females in the house, no bathroom access!
