Enrol for counselling at a question mark abuse centre?walkersworld said:what should i do ???? next????
Spark123 said:Firstly turn the cooker MCB off at the fuse board. With the multimeter set to ohms range can you measure the resistance from the cooker switch to the cooker chassis?
Spark123 said:Spark123 said:Firstly turn the cooker MCB off at the fuse board. With the multimeter set to ohms range can you measure the resistance from the cooker switch to the cooker chassis?
