Electric Shower Help Please.
Good work. FYI if you isolate the shower after every use, you may want to consider stopping doing that as is it may be what causes loose connections over a period of time
Hasn't happened with my MK shower switch in what by now must be tens of thousands of operations.
Not saying it's 100% guaranteed to be the cause of every burnt up connection in a shower switch, but I still stand by my advice. If the switch is a bit loose in the ceiling as they sometimes are, pulling that (usually stiff) switch repeatedly every day could certainly cause the connections to loosen over time.
Isolating the shower after every use isn't really necessary either, most people don't isolate the cooker after every use or a ring final circuit, so why the shower?
I don't know why others do it.
My switch is also functional, which is why it gets used 2-3 times each day.
And what must you be if you decide that that is what must be happening, and not that there's more than one person living here?
1) You have no grounds for not believing it.
2) Who is Kevin?
3) You really aren't very good at this, are you.
I always thought the reason cookers weren't isolated is because they normally have a clock which needs to be permanently powered to keep time.
The instructions for most showers however, say something like this example from Triton:
As far as I can remember, none of the shower isolators I have changed have had loose connections, it has been the contacts that have overheated. When operating the shower isolator post showering the contacts won't actually have any current flowing through them at the time, so won't burn or pit from arching at this point. Therefore the damage must occur during the actual usage of the shower.
I would say that loose connections do cause a lot of the shower isolator burn ups seen, but I don't believe that repeated switching has much of a loosening effect other than where the terminals are not as tight as they should be to start with. If the cores are properly dressed and formed before terminating, the copper strands allowed to relax and settle before nipping up again then there shouldn't be any problems (save from the cases that are down to resistance within the switching contacts).
A lot you see burnt up have clearly had no care taken fitting with conductors forced back into the box, and I'll but they never got nipped up after the conductor was forced right over to one side causing the strands to settle. Granted the crabtree style makes it easier to terminate without forcing stuff back, but it doesn't fix the problem of terminals not being correctly terminated to start with
Don't forget manufacturers instructions are guidance only and don't have to be followed especially when they are wrong.
As there is no requirement for a shower isolator in the regs these instructions are clearly wrong.
Don't shoot the messenger. I was just suggesting why people turn off their showers at the isolator. They even print it in bold and tell you it "MUST" be done because its' so important.
Perhaps you should write and tell Triton and (& the others) they are wrong. When you do, please post back, it will be interesting to see their reply ;)
I agree, its a case of the tail wagging the dog sometimes
