Electric Shower Replacement
30 Dec 2006
Carmarthenshire
Hi People !
I recently removed my old 8.5kwTriton T60i and replaced it with a 10.5kw Triton Bewitched model. My question is, now that the shower is installed and working fine, is it safe !
The house was completely rewired 5 years ago so has a modern Distribution Board (with MCB's). The Shower cable appears to be 6mm (same as cooker cable) and there is a 40amp MCB fitted at the Distribution Board. The distance from the board to the actual shower unit, including the drop down the wall is approximately 6 metres, the cable is buried in a plastered wall for just over half of the distance, the rest being exposed in the attic area above the insulation.
I understand that preference these days is for 10mm cable to be used, but, i am where i am, so would welcome any assurance that it is safe as it is. If necessary, would changing the MCB make it safer ?
Many thanks for any advice/reassurance given.
Vernon
______________________________
Lynda moderator
The WIKI forum is for questions about WIKI, NOT to ask other questions, your post has been moved
I cannot reassure you this arrangement is safe.
6mm² cable is only good to around 8.5kW.
40A is only good for 9.2kW.
You need to change both.
10.5 kW= 45.7A
Plus, you need to assess installation method & cable length in relation to cable size and whether you have main equipotential bonding & supplementary bonding & RCD protection as per manufacturer's instructions.
That was fast and much appreciated :)
Having bought the shower just yesterday, Im wondering if its a better option to return it and exchange for an 8.5kw model. Whilst changing the MCB is easy, replacing the cable would mean hacking at the wall which is best avoided i guess :(
Thanks again for your reply :wink:
If you can't replace the cable, then limit the cable load to 8.5kW.
But it is worth installing/ upgrading meb's & supplementary bonding & installing an RCD if not already fitted.
I doubt they will let you return the shower in a used condition unless there is something wrong with it. Obvious reasons.
Took the shower down, dried it with a hair dryer and B&Q echanged it for an 8.5 kw model with no fuss at all.
Mission Accomplished !
B&Q will return anything lol. There was a fit blond girl working on the returns desk last time i was there. what would she know about showers or belt sanders? :(
Being blonde, i suspect showers and belt sanders may not be her strong point............but, i dare say she has some hidden talent!
Hey, don't knock women!!
There was a girl who used to work at my local hire shop. I hired a chain saw that didn't work so I took it back.
After 5 secs, she told me I had forgotten to sprokle the gogglewazzer (or whatever it was, I can't remember!)
She certainly knew her stuff, yet looked sweet and innocent about all things mechanical!
