Hi People !
I recently removed my old 8.5kwTriton T60i and replaced it with a 10.5kw Triton Bewitched model. My question is, now that the shower is installed and working fine, is it safe !
The house was completely rewired 5 years ago so has a modern Distribution Board (with MCB's). The Shower cable appears to be 6mm (same as cooker cable) and there is a 40amp MCB fitted at the Distribution Board. The distance from the board to the actual shower unit, including the drop down the wall is approximately 6 metres, the cable is buried in a plastered wall for just over half of the distance, the rest being exposed in the attic area above the insulation.
I understand that preference these days is for 10mm cable to be used, but, i am where i am, so would welcome any assurance that it is safe as it is. If necessary, would changing the MCB make it safer ?
Many thanks for any advice/reassurance given.
Vernon
______________________________
Lynda moderator
The WIKI forum is for questions about WIKI, NOT to ask other questions, your post has been moved
Vernon
Lynda moderator
