LOLThat's easy for you to say.
I assume a 10½KW shower heater has 3 similar 3½KW elements but I've never thought to measure. Personally we use ours on low power as neither of us like it either very hot or stinging pressure.Yes good point, but I tink that sometimes they are not equal, perhaps intentionally and probably not always. Obviously we can only measure then cold and once warmed up that will vary but it gives us an initial rough idea.
Perhaps they are designed to be based on a logarithmic sort of difference rather than linear but then at least two of them equal to make production runs more economical.
One manufacturer might bias them logarithmic or geometric and another identical , with either 2 or 3 elements, and which one will be more successful?
Difficult to answer, even for them, there are other factors involved with their decision for greater success or less success.
Only hindsight can confirm their decision success/failure/50 shades of grey.
All we can do is make an approx linear guess then see if it appears to be somewhere near considering hot/cool and manufacturing tolerances and see if it tallies .
One reason I noticed these things is to make a water warmer for a handwash in my shed, I had a few different shower units for spare or repair and decided to measure element resistance so I did a quick calc for each different rating then observed measurements.
My intention was to consider altering connections so the elements could run in series rather than in parallel and calculate the expected temperature rise that might be achieved.
Some of you might have insider information that proves me right or proves me wrong!
Yes, it was just a warming of the water needed and 7 to 10Kw would have been too hot and expensive to run so I thought "hey perhaps two elements in series for quarter power and the testing went from there really, thats when I noticed some differences and maybe more than production line tolerances seemed likely on some, especially the three element varietyRealistically washing hands isn't much of a different requirement to a shower so I very much doubt you'll be wanting to reduced the power by series wirin
Realistically to wash hands will require a relatively fixed amount of water, the flow rate from a 3KW heater is so feeble it is likely to be in use for twice as long as a 6KW and suddenly the mathematics kick in.Yes, it was just a warming of the water needed and 7 to 10Kw would have been too hot and expensive to run so I thought "hey perhaps two elements in series for quarter power and the testing went from there really, thats when I noticed some differences
I think that some of us are as stark raving mad as people who try to get rid of acne with sandpaper - why do they do it?![]()
Just in case that's aimed at my post the freezer was in the attatched garage and the chilled air entering the house with the sheet of ply effectively sealing between the house and garageI`m glad that, apparently, a number of people put a fridge or freezer in a confined space 9such as the pantry under the stairs and leave the door open hoping it will cool the room only to find that actually it heats the room.
