    Dismiss Notice
Electric UFH under carpet on off peak
Discussion in 'Electrics UK' started by flyingsparks, 23 Jun 2013.
  1. flyingsparks
    flyingsparks
    27 Sep 2004
    1,300
    Thanks Received:
    82
    Country:
    A customer wants me to fit under floor heating in there hallway under carpet, but on an economy 10 supply. I don't think this is going to work as the time it takes to warm up, I think it should be on constantly and switched using the thermostat control? Right, or wrong?
  2. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,052
    Thanks Received:
    1,910
    Oxfordshire
    Country:
    Correct. Economy 7/10 for heating is designed for storage radiators etc where the heat is built up over night and released during the day.
    It's pointless for underfloor mat/loose wire systems (eg Warmup) as teh floor would only be warm between 11pm and 6:30am. That type of underfloor system is not designed for space heating, only to warm your tooties.
    Economy 10 is typically used for electric only installations using radiators and a system like THIS
  3. flyingsparks
    flyingsparks
    27 Sep 2004
    1,300
    Thanks Received:
    82
    Country:
    As I thought then, will tell them the good news tommorow! Cheers
  4. Lectrician
    Lectrician
    18 Jul 2004
    8,399
    Thanks Received:
    380
    Devon
    Country:
    It will still receive cheaper lecky during the off peak times, but will also stay warm during the peak times.
  5. ericmark
    ericmark
    27 Jan 2008
    15,178
    Thanks Received:
    1,357
    Llanfair Caereinion, Nr Welshpool
    Country:
    Depending on original design of course but in the main first job is dig up floor and lay insulation then the heating mat and then the surface finish. It does take a long time to warm and cool and is only suitable for where a home is heated 24/7 and would also need some other form of heating. The problem is there is no control as to heat output only energy input so you can easy in spring and autumn end up heating a house which does not require it.
    In a bathroom underfloor heating does dry the floors but in a wet room the cooling effect of the shower water means it takes at least an hour to dry the floor which is about 15 minutes quicker then without the heating which clearly is no real advantage.
    To fit underfloor heating upstairs where there is no real need to install massive amounts of insulation works far better. My son has installed underfloor heating in the bedrooms and it does make the floor warm to walk on. However it is not electric and he does still have radiators in the room.
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Ask them if they would consider lagging their radiators.
  7. Click-Sure
    Click-Sure
    6 Feb 2008
    1,309
    Thanks Received:
    11
    Staffordshire
    Country:
    If theyre having carpet you may as well put the heating mat under the celotex insulation.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
