If they are charging using a granny lead, there is no way of knowing.how can these people not know how much electricity they are using?
However anyone with ain installed EVSE will know as all of them report this and other information via the app.
I'm impressed at the impressive suggestion of such sheer wilful ignorance: "there is no way of knowing"If they are charging using a granny lead, there is no way of knowing.
so how many miles per kWh do you get based upon the consumption from the gridI'm impressed at the impressive suggestion of such sheer wilful ignorance: "there is no way of knowing"
In this home, as in many others, the car is charged by a granny lead on most nights, and I'd be hard pressed to avoid knowing how much electricity is used to charge the car.
the odometer is based on how many times the wheels go round, tyres of the same spec vary from batch to batch, so unless your mileometer is recalibrated at every tyre change, and periodically recalibrated as the tyres wear down - then it is not accurate, the worst van i had was a maestro, its milage ws out by 12.5% the best was my wifes E300TD only 3.4% outNo, that only applies to the indicated speed, the speedometer. There is no standard I am aware of, for the odometer accuracy. I have access three speedometers in my car - The default analogue dash, a digital version which is direct reading, and the satnav. The analogue dash reading is deliberately configured in the software which runs it, to read around 5% high. The other two are accurate. Likewise the odometer is accurate.
I also find the fuel range accurate, but it constantly revises itself, dependent on driving style, and the terrain. It bases the calculation, on knowing fast it is pumping the fuel/injector timings, versus distance covered. If I could be bothered - I have access to the software, which allows me to more precisely calibrate the calculation.
here is a picure of some tyres that I compared, they were all the same spec, 195 65 R13 (if I remember correctly)
~ 5% diff
yes at high speeds the tyres rolling diameter will increase a little (so indicated speed may not rise as fast as actual speed) small percentage changeI once did a bit of research on the subject, and what I found was there was very little variation, because the important figure, is the 'rolling diameter', rather than the measured diameter of the tyre.
exactly, and EV owners are being hoodwinked into thinking their EVs are far more efficient than they actually are.
from what I understand from others who have EVs and charge at home - they have no knowledge or no way of knowing how much electricity they are using, all they have is the misleading numbers presented on the dashboard.
least with an ICE vehicle you have a very simple mechanism in determining exactly how many mpg you are getting (which is often quite a bit more than the cars computer will have presented)
I'm intrigued - how can these people not know how much electricity they are using?
It's kind of oddly impressive to have aquaintances with such an unusually distant relationship with reality - perhaps it is an emerging niche form of non-attachment to reality meditation practice?
~ 5% diff
but diameter is all important and a bigger diameter will make speed and distance appear to be less on mileometers and speedometers that rely on how many times the heel spins
and it is all a very linear equation circumference =pi * dia
and being linear a 5% increase in radius will mean a 5% increase in circumference
