I have found an old electrical doorbell, the type that makes a big sound and I would like to install it Does it need a transformer and can I power it via creating a spur from an existing lighting spur, or do I have to hunt for the lighting ring?
Almost certainly. What voltage and current is the bell?I have found an old electrical doorbell, the type that makes a big sound and I would like to install it Does it need a transformer
One and the same thing. Lights are not wired in a Ring.and can I power it via creating a spur from an existing lighting spur, or do I have to hunt for the lighting ring?
Hi - I didn't know that lights weren't on a circuit, thank you for that information.
Where then would I connect the wiring for my bell, by breaking into any lighting wiring nearby and using a junction box perhaps?
i would recommend getting a spark as you don't seem to have enough knowledge for what you intend to do. no offence intended.
I despair. Installing a doorbell must be the single, easiest electrical task going.
Which is one of the reasons why I asked him toNot all chimes have two terminals like the one in your picture.
If he does not have instructions for it, it may not be immediately obvious which terminal is which.
Take the cover off the bell and post a picture on here, .
[quote="Taylortwocities";p="2202853]I despair. Installing a doorbell must be the single, easiest electrical task going.
Would you say that if I had posted for advice about the chime?
