- Joined
- 17 Oct 2012
- Messages
- 21
- Reaction score
- 3
- Country
Our house has an extension that has its own consumer unit wired off of the main unit in the hallway behind. When we have a certain amount of rain (generally heavy), the extension CU trips out. I have narrowed it down to the socket ring as the lighting ring will stay on. We have two external supplies, one going to an outside light and another goes up to a garden shed.Both these supplies are on a fused switch spur, which I have removed the fuses from to see if it is either of these causing the trip but no joy. I have had all of the socket fronts off to see if there is any signs of moisture or dampness getting in directly somehow, but all are dry. I've checked the loft space to see if anything is leaking directly onto any cables up there but all is ok.
My assumption is that water is getting into the cavity somehow and collects or reaches somewhere causing the short. We have lived in the property for 6 years and this has only started happening in the past six months with no works carried out that might have caused it. Would an electrician be able to pin point where a problem is occurring without basically ripping everything out? (I appreciate most do not have X-ray vision!)
Many thanks in advance.
Andy
Andy
