- Joined
- 27 Jan 2008
- Messages
- 29,249
- Reaction score
- 3,588
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It will vary area to area and I can only speak from experience when in 2006 my son and I completed a wet room where the builder and his electricians ran off into the wilds of Wales.Sorry guys, and thank you for your replies, but my problem is not knowing how to install the correct electrical installation, its the fact that i'm not qualified or have any test equipment.
I know or can find out how to install to the current regs, but i'm just a 60 year old heating engineer, not a qualified electrician. will the building inspector accept the work done by me.
The inspector on his first and only visit asked "Who would sign off the electrics" to which my son answered he would. My son said how he had a C&G2391 but the inspector was un-impressed. My son then said how I held a degree in Electrical and Electronic engineering which he accepted.
Although I also had a C&G2391 the inspector did not know that and it was apparent the inspector did not have a clue as to what the qualifications really were. But at least this was sorted up front before we started the work.
On completion the installation certificate to submitted to the council and the completion certificate arrived in the post.
Clearly we did know what we were doing and there was no attempt to skimp on the job. We also had the meters required and these were on display when the inspector arrived.
I would consider a full test set it just too expensive for DIY and that a cheap tester like this one
In the view of what I know of the building control to date I would print out advert and tell the LABC inspector you have ordered one of these to do testing with and ask them if they will accept the paperwork from you.
My son also had dealing with Liverpool LABC and it was completely different. They were really helpful and knew exactly what the C&G 2391 meant and allowed him to test and inspect without a problem.
Much will depend on when you started the job. You may not be required to show test results anyway. The new Part P (and you must remember if started before April you will be on the old one) states that a post installation electrical installation condition report is to be accepted but really there is only two people who can answer the questions.
1) The LABC inspector.
2) Yourself.
Only you know if you can really do the work safely. And from what you have said on here if I was the LABC inspector I would not be happy.
