I can't, because radials don't have spurs, only rings.Can you tell us where in the OSG that it makes a distinction to rings and radials as regards spurs?
I don't think that people are offended by your repeated attempts to make yourself look foolish, are they?How can I say this without causing offence to people on a DIY Forum? I'll try.
Or reading the OSG?There is a lot more to electrical installation design than simply doing what everyone else does, following cheat sheet, reading a DIY book etc.
It is encouraging that you are starting to realise that.As good as BS7671 is, it is not an educational tool. Having limited knowledge is a good thing, so long as the limitations are not exceeded.
It is certainly a useful guide.Long gone are the days when the Regs were a do this or do that publication. The OSG has to some extent replaced this.
Is this patronising tone meant to upset me, or make you look superior and clever, or make you look petty and foolish?If you wish to know more about this subject without going too deeply into engineering and science, perhaps you could post on the IET Forum what you think is correct and ask for clarification. If that doesn't satisfy you, come back to this thread and ask again. I may be able to dig out some noddy guides from several years ago that might help (if you really want to plumb the depths of engineering).
Assume that I do know enough to understand your explanation of why an unfused branch from a radial circuit in the same sized cable, and therefore complying with 433-02-01 just like the rest of the circuit, needs to be limited to one socket etc.In the meantime, follow the OSG. It is there to offer relatively simple guidance. Follow accepted working practice and try to understand that unless you are a suitably qualified (Chartered) electrical engineer, the IET's publications shouldn't be dismissed without careful consideration.
No, it makes reference to spurs in a section which deals with both rings and radials.Appx 8 does indeed make reference to spurs on both a ring or radial final circuit.
It doesn't really, because with rings there's no limit on the number of sockets you can have*, and therefore no limit on the number of non-fused spurs*, and with radials there is no limit on the number of sockets you can have*, no matter how "branchy" or tree-like the circuit is.However, I believe it is very confusing: on a ring final, the idea is that non-fused spurs do not exceed the total number of outlets & permanently connected equipment. Further, those non-fused spurs can only feed one 1363 outlet each. This together with floor area limitations limits load on the circuit.
No it's not, it's a radial final circuit. A spur is, according to their definition, a branch from a ring final circuit.However, with a radial circuit, the whole circuit is effectively a chain of spurs from spurs (using their above definition).
Not at all.So the OSG seems to contradict itself, does it not?
That is wrong.For radials or rings, only one non-fused spur per socket or junction box connected on the main circuit cable(s).
There doesn't need to be an exception, and the guidance is explicit.I'm sure the IEE would have spotted it, if it were true. The advice in App. 8 is pretty clear. If there were an exception , the guidance would be explicit.
It does not define spur, and it does not define branch.It doesn't define a different kind of spur for radial sockets. It refers to them both.
It does not define a spur. It does not repeat the definition of spur from the Wiring Regulations, nor does it invent a definition of a "radial spur".It goes on to define a spur. It does not go on to define a ring spur and a radial spur.
In the introduction it says:It's very easy to pick out things the Regs, OSG etc. do not say, but it is important to focus on the things they do say. Don't look for smoke and mirrors, especially in the OSG. The OSG is intended to make things clearer, easier, better and not muddier, harder and worse. It is there to help and not hinder. It's the best guide there is.
I'm going to refer to the Trades Description Act and determine if the subject title of this thread contravenes it![]()
