At that point it was using its first stage, which used kerosene. The other two stages were hydrogen fueled for better ISP.Nohing new about hydrogen powered flight...
Petrol - liquid at normal temperatures and pressures. Will run out of a ruptured tank and pool on the ground, inside a vehicle, etc. Highly combustible vapour which is heavier than air.Especially if you lit it.
Train and HGV crashes might get interesting. Remember why balloons use helium.
They probably use too much nickel, which is relatively expensive.An interesting suggestion I saw was to use ye olde NiFe cells for storage. They aren't efficient in terms of size, but they're much lower tech and polluting than fancier lithium alternatives.
Electricity beats hydrogen every time if all things are equal. There's a few areas it might make sense in the future but it'll almost alway be more expensive and less efficient.
At the moment hydrogen is almost all made from natural gas, which means it's a fossil fuel. Electricity from the grid has a lower carbon footprint now, and is improving every year. So right now, electricity all the way.
In theory we might see green hydrogen made by splitting water into oxegen and hydrogen, powered by renewables. But it is currently absurdly expensive so it isn't a significant factor right now.
Even when the price drops in five to ten years the process is inefficient to split water, transport the hydrogen and then convert it back to electricity for use, compared to storing in a battery and then using electricity. Which means it's more green to use batteries in nearly all cases.
The exceptions are when batteries aren't an option and you can't connect to a grid. Seasonal storage for example, there batteries or grid electricity can't work, so hydrogen might be useful.
These days Lithium Iron Phosphate, or LiPo, is the cheap and cheerful flavour of the day. No expensive cobalt or nickel.
Another more recent theory involves the airship's outer covering. The silvery cloth covering contained material including cellulose nitrate which is highly flammable. This theory is controversial and has been rejected by other researchers because the outer skin burns too slowly to account for the rapid flame propagation and gaps in the fire correspond with internal gas cell divisions, which would not be visible if the fire had spread across the skin first. Hydrogen fires had previously destroyed many other airships.one of the reasons is that the highly inflammable doped fabric envelope of the Hindenberg caught fire, and for a long time people thought it was a hydrogen fire.
I believe it's widely mined, for example Australia is the largest producer of ore and Chilie has the largest reserves, but it is shipped elsewhere often China, for refining.Li price is going up fast, and supply is dominated by China. No mine is nice but Li is problematic.
A complex problem..
Because our nationalised generating industry owns lots of nuclear power stations?We're currently importing power from the EU, at about 2 NP stations rate.
