Hi all
A spur taken of the 32 amp ring main, does it have to be 2.5mm or 4mm cable? Surely if you use 2.5mm, then plug 2 things rated 3kw in to the spur, asuming your spur is a 2 gang you will over load the cable. If you use 4mm cable then could you have two, 2 gang sockets?
Thanks James
Thanks James
