J
johnmf
hi guys, not a DIY question but ive seen some previous posts on here from sparks who may be able to help me out so thought id ask......
i have picked up a job which involves joining big swa cable (ive worked with 150mm before but have been doing domestic for last few years)
situation is a 240mm 4 core swa coming up out of a duct at floor level and sitting vertically against a wall, cable only comes out of floor by 700mm. i need to join this to another piece of big swa that will go on to feed a busbar.(this is all inside a building by the way)
the new cable can be 240mm or i can go down to 185mm (will be fused correctly obviously and loading assessed with plenty to spare)
i have two options as i see it,
1, use a resin joint kit or a heatshrink joint kit (additional protection will be assessed and provided). problem i see with resin kit is it could be fun to fill seen as the submarine will be vertical!
or i can use a suitably rated enclosure and either lug the cables onto terminals or thru crimp them (an enclosure is my preffered method). can anybody suggest a particullar make of enclosure that would be suitable????
also has anybody used the shear bolt joints? if so are they any good and can they be used to join 240 to 185 cables?
opinions please.
regards
opinions please.
regards
