^ Still can't get to grip with one line title descriptions...oh well...
This weekend, I am finally laying my laminate floors (have been acclimatising for a good month!...getting round to other stuff first).
Fairly confident I should do a decent job, but have a couple of worries:
Firstly I need a to know the best method of making sure that the first strip you lay is the same width as the final strip (so to ensure the final strip is not a really thin line). There is probably a really simple maths sum you could punch into your calculator and hey presto - unfortunately I'm not too sure what this i
Case of measuing the room width x the width of a single laminate and add a dash of division?
There is an exposed brick chimney breast in the centre of the room (parallel to the sides of the wall I'm making my way across) - I'd also need to make sure a thin strip of laminate is not going to fit oddly across this as well.
I'm also wondering if it's best to add skirting across the brick chimney breast (2nd query), beading or leave blank and add cork strip beading (which I cannot seem to find anywhere that sells the stuff!!).
Might sound a bit chaotic above but I'm starting to add the two in one insulation so ever so slightly anxious!!
Many thanks...
Many thanks...
