Entryphone Wiring Help
11 May 2013
Glasgow
Hi Folks, I'm changing the entryphone in our flat from an old Videx one to an Entryphone 201. I've followed Entryphone's wiring guide but when I connect the green to B,F or G I just get a beeping sound coming through the handset. I've tried wiring B, F & G together but same result.
There's also a 6th wire (black) but that was unterminated on the old one.
Any help appreciated, Cheers
Old Videx
[/img]
New Entryphone
Bit of an update.... wired as is in the photo below the key button opens the door but pressing the call button at the door does not sound the handset & there is no sound to the door or back from the door. If I connect B F & G together a constant beeping comes through the handset.
are you changing just the handset ? is it a single flat or multi ? and what makes you think you can just swop over the handset ?
It is simple, you just need to know more about wiring than I do!
The brand doesn't matter as long as you change like for like & I am the landlord so it's all good!
sorry it does not allways work like that ! your old videx has a buzzer probably ac call signal your entryphone handset MAY not support AC call input. some do some don't.
As above - the handset you have obtained is not compatible.
Send it back, then buy a Videx 3101 instead, which will wire in exactly the same way as the old one did.
Hopefully your random wiring connections won't have damaged the main panel or the phones in the other flats.
Ah ok, thanks guys, very helpful. I've connected the old one back up for now. I'll speak to the guys at Entryphone tomorrow where I bought this one & see if they have a model that will work. Failing that i'll go with the Videx 3101.
Cheers
